When the water level is properly set, the car will still spit out water after the car is turned off. It isn't just the first time, but rather several times so that eventually too much water is spit out, and then the car will run hot. The fan clutch; the radiator cap and the motor seem fine. The motor does not run hot when the proper water level is set. The question then is whether or not the radiator, which clearly functions when the motor is running, is somehow responsible for the build up of temperature and pressure when the car is turned off.
Any suggestions?
Any suggestions?
