'62 Steering column color - NCRS Discussion Boards
  • David K.
    • February 1, 1976
    • 592
    I know the "book" says they are to be black. But, I was having some serious problems with fisheyeing. In stripping the column, we found that the column was originally painted fawn to match the interior color. I personally never saw a '62 with a painted column that matches the interoir. Maybe the early number, 399 is a carryover from earlier years.
  • Terry R.
    • March 1, 2005
    • 359
    Re: '62 Steering column color
    Hi Dave My April built '62 steering column is black with Fawn going about half way down. I got points off at Waco for the Fawn going below the bracket.
    • Paul B.
      • January 31, 2007
      • 310
      On my late April '62, the fawn fades by the U bracket and then the rest is black. I don't know if this is how it came from GM however?
      All the best,
      Paul
      • Terry R.
        • March 1, 2005
        • 359
        I'm probably about 6 inches below bracket but I'm not sure whats right either.
        • David K.
          • February 1, 1976
          • 592
          Mine was fawn, all the way to the steering box. Maybe a change is needed in the manual? Thanks for reporting in!!!
          • Dennis A.
            • April 30, 1999
            • 1010
            I have it that the steering column mast is painted a slightly dull gloss black. Interior gloss color is painted from the steering wheel end to 1 1/2 inches below the column bracket. the notch (elongated hole) on the side of the column marks were the interior paint should end....
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              Hmmmm, '62 #483 below....Rich
              • Mike E.
                • February 28, 1975
                • 5134
                Dave--
                No reason to change the manual, because fawn all the way to the steering box is not correct. I can't say that yours wasn't painted that way, but the over 700 original cars I have documented over the past 30 years have not had interior color past the bracket that affixes it to the bottom of the column. If you're absolutely convinced that yours came that way, then restore it that way, and take the hit in judging. Otherwise if you want the points, you'll need to do it black. The judging manual process has to go with what was standard, otherwise there is no standard. I know an original-owner low-hp car that has a 2268 generator--it hasn't been changed--but we can't change the manual to indicate that either generator is available on any horsepower car. That's just not the way it was.
                • David K.
                  • February 1, 1976
                  • 592
                  My previous '62, was a late no.(13787) and was white on red. It's column was black all the way. But, there is NO doubt, this early fawn '62 had a fawn column under the old Bubba black paint(many coats!). Was this possibly a variation on the fawn cars? Was it a possiblity on the early cars, that were painted this way? But, two have said their April '62 cars and fawn on the column. Hmmmmmmmmm Dennis, what color is your interior?
                  • Dennis A.
                    • April 30, 1999
                    • 1010
                    Fawn Beige is the color....
                    • David K.
                      • February 1, 1976
                      • 592
                      Mike, we posted at the same time. My car is now "as is standard" according to the book. Which is not as it left St. Louis.
                      • Phillip G.
                        • April 30, 1992
                        • 42
                        I have a 62 that I purchased from the orginal owner 2 years ago. Their was no paint on the steering column past the fire wall into the motor compartment. In removing the VIN tag, no paint. The paint from the firewall into the car was painted black, with Red on the last 5 inches to match interior. The car was never hit, never repainted, still had all the orginal parts. Was it possible that this was an unusual situation?
                        Phil Gardner
                        • Dennis A.
                          • April 30, 1999
                          • 1010
                          Phillip....
                          I never seen a "unpainted steering column inside the firewall. all were painted black up to the interior color was applied. The VIN tag was riveted on before the painting.
                          • Phillip G.
                            • April 30, 1992
                            • 42
                            thanks much, your help greatly appreciated.
