Need help with a 1969 I am looking at. The serial number is 194979S727751. The block is stamped 19S727751 VO80 IXH. Should it be 79S727751? Thanks for your help. Joe
1969 vin/engine numbers
Re: 1969 vin/engine numbers
Joe, at least per my 3rd edition JG 19S7xxxx would be the expected sequence.Bill Clupper #618- Top
- Top
The only "XH" suffix codings I can find are for the following applications:
1968 truck with 310 hp 396 and 3 speed manual trans;
1969 truck with 215 hp 350
What is the casting number of the block and cylinder heads?In Appreciation of John Hinckley- Top
Kent
NCM Founder - Member #718- Top
