I am restoring my 69 L-46 coupe and currently have the body off the chassis. I have several questions:
1) Should I restore my own contol arms or should I buy the already restored ones? One of my lower control arms appeard all bent up near the shaft, like some yahoo wailed on it with a hammer. Should I straighten it or is it possible that it was like this at the factory? During the restore, what has to happen to the shaft? Does it need to come out? Are there bearings or seals that need to be changed? There is some pitting on the control arm and shaft. Should I use filler on this or just sand down the metal itself? Would sanding the shaft down compromise its integrity?
2) Some of my chassis hardware has become so rusted that the markings are no longer visible without considerable effort. Should I reuse them anyway for the sake of originality or should I replace them? Does anyone sell new correct hardware? Who is the best place to go to for hardware refinishing?
I will try to attach some photos of the control arms where they are bent.
Thanks in advance for your suggestions.
Mike
Mike
The initial cost may seem like a lot but the $200-$300 that Joe mentioned is PER BATCH and trust me you WILL NOT get it all in one batch...at least I couldn't...always forgot something. I sent my initial batch out for plating and then bought a small caswell kit...ya I do some things backwards.
Since then I've had to fire up my kit twice and I'm getting ready to do a third and truely final batch in about a week. The convienience of being able to plate your own fasteners is priceless. You have to do all the prep work yourself anyways...the plating is the quick part.
