Tearing out the interior on a 42 year old car is a bit like an archeology expedition. I've found and saved numerous "inspected by" tags along with a small treasure of change. While removing the original carpet and jute pads I have uncovered what appears to be the remnants of a meatball replacement of the antenna at some point in my 66 roadster's life. (see picture attached). You can just see some Bubba with a drill hacking away at the backwall to provide an opening to easily get to the antenna.... makes you kinda of sick!
Any thoughts as to what I should do with the hole? I am not doing a full restoration at this point. Just getting the car ready be comfortable for my summer journey on Rte. 66. Should I seal this hole up in some way for a temporary fix or should I just leave it until I do the proper restoration at some point in the future? There's no indication that there has been any water come through this hole in the past. The wheel well is sound and the spare tire tub are in place so this is fairly remote spot. When it does come time to restore the car, is there a process someone would recommend to do a final repair?
I'd appreciate any thoughts.
Cheers
Mike
Cheers
Mike
