Does any vendor sell a harness from the power window switch to the antenna? I can't seem to find one. Could I make one? What color are the wires and what is the routing? Or is this in the AIM somewhere? Thank you.
'66 power antenna
Re: '66 power antenna
Larry -- I think you mean power antenna switch (not power window) -- there is no specific (separate) power antenna wiring harness. For 1966 MY, all rear harnesses had the wiring for the P.Antenna. You can identify this by the 14 gauge black and 14 gauge black with whitestripe (in '65, at least; might be just black and white 14 GA wires in '66) at one end of the body connection for the rear harness under the dash, at the left side cross-brace, or behind rear bulkhead, where it branches off to the P.A..
But if you mean from the P.Ant switch to the under-dash instrument harness, I'm sure that these are available (with switch) from the major repro houses.
The '65 wiring schematic really doesn't show this wiring on their body and tail lamp diagram, but I've sketched in my own (including back-up lights, which are also not shown in the '65 diagram)- Top
