C3 Door hinge spring install - NCRS Discussion Boards
  • Michael G.
    • March 2, 2008
    • 485
    Would someone please reveal the secret to installing a new door hinge spring. It appears to be correct in design. Came with a rather lame instruction procedure. I'm assuming that this tool was designed to allow you to install the spring without removing the hinge. I cant seem to move the spring into the slot once I have applied pressure with the tool. I have tried to find the best angle of the door and still be able to work in the gap.
    I can't imagine what I'm doing wrong but I'm sure it's something stupid. This is my first time at a door hinge spring so please have mercy.
    Thanks, Mike
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C3 Door hinge spring install
    Thanks, Mike
    Might be hard to explain. First put the spring into the hindge in the approximate position it needs to be, except it will drop down a bit. Then take the tool and pull the bottom of the spring past the serrated wheels. The use a small hammer and tap it upwards until the groove at the top snaps into place.
    • Michael G.
      • March 2, 2008
      • 485
      Thanks Wayne,
      Apparently I am using the proper procedure. It's the upward tapping that gets tricky with my power window wire tube running right across the line of fire. Will try again tomorrow when I can have someone hold the wires out of the way. Thanks again. Mike
      • Don L.
        • August 31, 2005
        • 1005
        You have mail...
        Don Lowe
        NCRS #44382
        Carolinas Chapter
