Deciperhing these Carbs Numbers... - NCRS Discussion Boards
  • Gregory M.
    • May 31, 1984
    • 178
    I have a 1968 435HP Coupe and am considering flight judging. I bought the car last year and the carbs have the following numbers:
    Rear: 3902353-EU
    3859
    2534
    Center: 3902355-EV
    3880 (or 3660)
    2913
    Front: 3902353-EU
    3859
    1893
    Are these carbs correct for that year and motor? Which of those numbers are date codes and what are they? Any help would be appreciated.
    GM
  • Kenneth T.
    • March 23, 2008
    • 631
    Re: Deciperhing these Carbs Numbers...
    Rear: 3902353-EU
    3859
    2534
    Center: 3902355-EV
    3880 (or 3660)
    2913
    Front: 3902353-EU
    3859
    1893
    GM
    Gergory,
    I am no expert, new here as well but I have an old GM parts book that shows your primary (center) carb as correct.
    The secondarys show to be correct part # 3902353 the second number shows to be 3660. There are guys here who will jump in a help soon.
    The one below is a 69, I believe?
      Rear: 3902353-EU
      3859
      2534
      Center: 3902355-EV
      3880 (or 3660)
      2913
      Front: 3902353-EU
      3859
      1893
      GM
      Your center carb should be a 4055 (3940929), and the end carbs should be 3659's (3902353). The carbs you listed are service replacements, made in 1973-74; the ones listed as 3859 are probably 3659, and the 3880 is probably a 3660.
