I have searched the archives and come up with two distinct methods for removing the front Coil Springs.
1) place a 18 inch , 5/8 bar stock in the shock hole and compress. Then place a floor jack under the a arm where it attaches to the cross member.
Then remove the two small and one large bolt from the a arm that hold it to the frame ,and release the tention on the bar stock until free. Then slowly lower the floor jack until spring has no tention. {inside removal}
2) Place A 24 to 30 inch 5/8 bar stock in the shock hole , compress , and then pickle fork and remove the spindle. then continue to release preasure on the bar stock until spring is free. {outside removal}
My questions are theses:
Which method is safer ?
Which method is easier ?
What length of bar stock is needed to release all presure off the spring before it is relased. Ie. How long is an unsprung spring?
Wanting to keep all my body parts in tact !
Jim
Jim
, can you describe the installation of the tool? Of course, a photo would be better.
