Wax Residue Removal - NCRS Discussion Boards
Wax Residue Removal
  • Joe W.
    • April 30, 2003
    • 26
    Wax Residue Removal
    What's the best method for removing years of wax residue on the lettering found on the taillight lens. I've tried soft scrub with a brush to no avail. Is there a solvent that will do the trick?
    Thank you in advance!
    Joe Walker
  • Brian M.
    • February 1, 1997
    • 1837
    Re: Wax Residue Removal
    3M wax and grease remover.
    • Louis T.
      • July 31, 2003
      • 282
      Hi Joe,
      I echo Brian's recommendation. Wax & grease removers are excellent to have around for a variety of cleaning chores, including cleaning stubborn deposits on a windshield, and certainly to prepare a surface for touch-up paint or fresh wax.
      There are other manufacturers that make similar products to the 3M, as well - Dupont, for one, and I personally use Klean-Strip (Aircraft Prep) Prep-All Wax & Grease Remover. Your local parts store or body shop supplier should have one of these in stock.
      Good luck!
      Louis
      • Robert C.
        • December 1, 1993
        • 1153
        most pro's use a bristle paint brush, one that you would get at an art supply shop.. you just flick away at the residue and it falls off!
        • Wayne P.
          • August 31, 1975
          • 1025
          A tooth pick works well for me.
          • Joe W.
            • April 30, 2003
            • 26
            3M Wax Remover, a toothbrush and a toothpick did the trick. Thanks to everyone for your input.
