The engine is ready to start and I have the wiring harness connected the way that I think it should be, but there is no sign of life when I turn the key.
Questions and observations I have are as follows,
1) There is a ground pin on the ignition switch but there is no obvious wire coming out of harness that could go into the plug.
2)The fusible links are good.
3) There is a loose brown wire coming off of the coil that is labled as W/R/B which I'll assume is white , red, black depicted on the wiring diagram as going into the bulkhead connectors
Anyone have a down and dirty wiring diagram I could take advantage of?
Thanks, Chuck
Thanks, Chuck
