C1 door striker shims # - NCRS Discussion Boards
  • David S.
    Infrequent User
    • July 31, 1992
    • 8
    On my driver's door striker I need 3 Shims to get alignment. I was wondering if this shim requirement is unusual. Door alignment on body is pretty good. thanks
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 door striker shims #
    David...
    The most I have found from tear-down is two, however; if the door fit good leave it alone. Check to make sure you installed the anti skid plates and as a note, 1956-60 door strikers have a thicker metal catch than 61-62's.
