C3 rear diff crossmember - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    I am doing a frame off resto on my 69 and have everything off the frame but ran into difficulty getting the rear crossmember off. I have read the posts in the archives and I understand now this is not unusual and with the advice in there I believe I can get it down but my question is do I have to? Is this item something that should be replaced for this kind of a restoration? Does this bushing actually wear out?
    Mike
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 rear diff crossmember
    Mike
    I see no problem with leaving it on. Most of the damage is done removing it.
    Lyle
    • Michael L.
      • December 15, 2006
      • 1387
      I still need to blast and paint the frame. If I decide to leave it do I need to take special precautions?
      Mike
        Mike
        Mike-----
        If the frame suffers from significant corrosion, I'd recommend removing the crossmember to inspect for possible damage to the cushion retaining tabs or cushion shells. The cushions are usually very long-lived. However, if there is corrosion damage to the cushion shells, that can create a later problem with the cushions "pulling out".
        Otherwise, if you don't expect any corrosion damage, there is only one reason to remove the crossmember. That reason is to make it easier to get out the next time you want to remove the differential and you don't have the body off the frame. When I have the crossmember out, I usually coat the inside surface of the cushions with a VERY light coat of silicone grease for this purpose.
        However, as Lyle points out, you can damage the cushions when removing the crossmember. This may well require replacement of the cushions.
        • Mike G.
          • July 31, 2002
          • 709
          mine was stuck on there pretty good. i pryed it off after removing the bolts . i replaced the bushings with new ones. they hammered right out.
          • Chuck R.
            • April 30, 1999
            • 1434
            Hi Mike,
            If your going to have the frame cleaned with some sort of media, I would definately remove the crossmember.
            You don't want loose media material setting in the mounts, this may cause issues down the road.
            If your going through the efforts to have the frame cleaned up, why not take a few more minutes and pull the crossmember off and inspect the mounts to play it safe. There's no better time than now.
            Chuck
            • Michael L.
              • December 15, 2006
              • 1387
              Chuck,
              Thanks for advice. The frame will get blasted so I will take out the crossmember and replace the bushings. It doesn't seem to me that I should cut a corner on something like that.
              Mike
              • Chuck R.
                • April 30, 1999
                • 1434
                LIke Joe stated Mike, the odds of the mounts needing replacement probably are fairly low. I pulled my VERY corroded rust belt crossmember from my 68 and the mounts looked surprisingly good.
                Unless they are severely checked up or splitting, they should still be ok to re-use.
                Chuck
                • Michael L.
                  • December 15, 2006
                  • 1387
                  I will check the mounts when I get the crossmember off. Will the WD-40 I have been soaking them with result in any damage to them?
                  Mike
                  • Chuck R.
                    • April 30, 1999
                    • 1434
                    If you leave the WD on them for an extended period of time, they may actually swell up and become deformed to the point of requiring replacement if you've drenched them.
                    In some cases, the rubber will shrink back into place once the excess is wiped off and they have been allowed to air dry, but it has been my experience that the rubber might harden up and/or split.
                    With rubber, probably the first dose of WD sealed off the air gap to the point where the rest might not have done any real good. The best way would be to have a helper spray the mount while you worked the crossmember to possibly flex the rubber enough to allow the penetrant to chase along any opening you may create
                    I wouldn't keep plowing the WD to them though until your actually ready to pull them out.
                    I was surprised at how easily the corroded piece of crap I had popped free with only one heavy shot of penetrant and a heavy pry bar working by myself.
                    As I stated in prior posts, I spoke with a tech. Rep. from Permatex who confirmed that their never seize could also be applied to the rubber mounts without the risk of deterioration.
                    Good luck with it Mike,
                    Chuck
                    • Michael L.
                      • December 15, 2006
                      • 1387
                      O.K. I was able to get crossmember off. Both of the bushings are toast. When I replace them on which side do I put the silicone grease or the never seize? Does it go on the part of the bushing that touches the frame or on the part that touches the crossmember?
                      Mike
                        Mike
                        Michael------
                        The lubricant goes on the inside surface of the cushion. Actually, you can put it on the "sombrero" bracket which is welded to the frame and which is the part that goes into the cushion.
                          Like this - it's a metal-to-metal joint.
                          • Michael L.
                            • December 15, 2006
                            • 1387
                            Thanks guys.
