Need help fellow members..........Had my cluster out for bulb replacement and cluster repaint after 4 months. Hooked everything back up this weekend, all the lights illuminate -great. But my oil pressure gauge (80lb) upon start-up and driving goes right over to end at 80LB, then upon idling it tapers back to 60-70LBs. I know I have not driving the car since summer but if my memory is correct it usually floated around 40-50LB mark. All I did was disconnect the brass fitting at the cluster and re-connect it. Is there a step I missed, air in the line, check the other end into the block, could the gauge now be faulty?? ( please don't make me take that cluster out again)......suggestions sincerely appreciated.
66 BB Oil pressure gauge acting strange....
Re: 66 BB Oil pressure gauge acting strange....
It had not been started in 4 months, car is on a charger in a very heated garage. I drove it 2-3 miles and gauge still goes all the way over to 80LB when driving and down to 60LB when idiling.....still too high comparted to what I recall. Nothing else done to the oil line except un hook it and re-connect it, except the neddle was moved around a bit by hand when I cleaned the gauge face to get the dust/lint off it before re-installing the glass cluster..........- Top
Are you using the same type of oil in the engine?- Top
How cold was it when you fired it up?
