'69 gas door - NCRS Discussion Boards
'69 gas door
  • Jeffrey S.
    • May 31, 1988
    • 1879
    '69 gas door
    Can anyone tell me if there is a washer under the screws that attach the gas door to the hinge? The AIM indicates a "P Washer". The Dobbins book clearly shows an external tooth lock washer. The photo in the Bizzoco book is unclear. I'm pretty sure the screws are chromed- are the washers, if any, also? Thanks for your help.
    Jeff
    Re: '69 gas door
    Jeff
    Jeff-----
    There was an external tooth star washer used with the screws that retain the filler door to the filler door hinge. Both the screws and the washers were chrome plated.
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Re: '69 gas door
      Joe:
      Thanks very much for the reply. What does "P washer" mean? I thought that it meant "plain washer". I always understood "L washer" to be a lock washer. Again, thanks.
      Jeff
        Re: '69 gas door
        Joe:
        Jeff
        Jeff----
        "P-washer" does mean "plain" washer (i.e flat washer). However, the washer part number specified, GM #138482, was an external tooth star washer. So, there's a conflict here no matter how you look at it.
