L 78 intake questions - NCRS Discussion Boards
  • Donald S.
    • January 23, 2008
    • 183
    on the underside of the intake manifold there is a cast date code marked [6.2.65.]i presume that this is june 2 of 65 correct for a mid july car ??also on the underside in the rear block off area of the rear water crossover there is a P stamped in the cavity does this mean anything ??also on the top side of the manifold where on later manifolds where the chock boss would be there is a T stamped into the raised boss does this mean anything ??? thanks for any help Don....
  • Joel T.
    • April 30, 2005
    • 765
    Re: L 78 intake questions
    Don,
    I have a couple of these manifolds. You are right about the date, and it would be "correct"for an early July car.. Reality is that nobody sees it.. so as I understand, it is not judged, just the same as dates on heads. Mine have the "T" but I have no idea what it means. I have never seen the "P" . What's most important to you is the part number (only one part number in 1965 for 396) and the Winters snow flake.
    Good luck,
    Joel
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Donald Smith (48429)
      ...the rear water crossover there is a P stamped in the cavity does this mean anything ??also on the top side of the manifold where on later manifolds where the chock boss would be there is a T stamped into the raised boss does this mean anything ??? thanks for any help Don....
      Donald -- I have a 2/17/65 dated manifold 3866963 (L78) with the "T" stamped on square boss on passenger forward. But the "P" stamped in the rear X-over block-off on the same side is a MIRROR IMAGE of an alphabetic P. How did they do that ?
      I suspect these are just inspector's stamps.
      • Donald S.
        • January 23, 2008
        • 183
        thanks guys i was cleaning it up today and found the P so i thought i would ask getting ready for engine assembly the short block is ready to pick up this saturday ...
        i have read that some manifolds were painted silver ??? or was this done to touch up a poorly masked manifold after the engine was painted ?? ie some survivor cars have been documented with orange and silver overspray on some engine components ...
        • Bill W.
          • March 1, 1980
          • 2000
          My orig. intakes did not have any silver paint . just light orange . I think the silver was only used for touch up on major orange mistakes....Bill
