C1 carb return spring -250hp placement - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2395
    Where should the front of the spring be attached? And where should the bracket be bolted? Is it on the intake bolt? The radiator hose and the temp sender are really close in this area.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C1 carb return spring -250hp placement
    Hi John,
    Interesting you ask as I was just looking at mine. Went to my 62 AIM, and also noticed in my Zip catalog there are 2 different ways for 61&62E or 62L. What year is yours? You didn't say. If 62, Early or Late?
    61&62E is like mine for my early 62 250hp(RC) ...1st picture. I bought this a while ago to replace the incorrect thermo housing on my engine. The bracket is the same part used on my 59 2x4 setup(2 pcs). However I'm confused & not sure if it mounts on the themo housing, or on the intake bolt either. My 59 AIM shows spring connected to oil fill tube.
    If you look at the same Zip part# CZ-749, it states 55-62.
    62L is this one according to Zip http://tinyurl.com/5jcg39
    which after 3-7-62 is the 3824300(I think), but was previously 3729808.
    62 AIM(pictured) does not show "Early" flavor.
    Rich
    • David K.
      • February 1, 1976
      • 592
      I currently have a very early '62. Back in '72, I bought a very late '62 (700 from the end). Both had their spring attachment on the piece of steel attached to the thermostat housing, as Rich showed in his first attachment picture.
      • John F.
        • March 23, 2008
        • 2395
        Mine is an April 1962.
        John
        • John F.
          • March 23, 2008
          • 2395
          Richard, Where did you get the bracket in the first picture?
          John
          • Mike E.
            • February 28, 1975
            • 5134
            In the 61-62 TIM&JG, page 55, 2nd paragraph under Linkage and springs, it spells out that there were three different "solutions" that GM used for this issue. They were not consistent in their approach to where the return spring anchored. For your April car, I would suggest that the bracket on top of the thermostat housing would be my first choice, with the bracket that bolts to the two intake manifold bolts as my second choice. Either should cause absolutely no problem when judging.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              John
              It came with the thermo housing......I bought via Ebay several months ago. Zip has the brackets too, and most other suppliers.
              Rich
