Does anyone know if the tubing connecting the distributor vacuum advance module to the carburetor on a '58 - 230HP is rubber or steel? Thanks, Susan
'58 Vacuum Advance tube
Re: '58 Vacuum Advance tube
Susan, The FI car and your 230 HP both use a similiar idea for the vacuum advance line. The front of your vacuum advance is hex shaped and has a threaded area which I believe is for a 3/16' curved steel line. Buy a piece of 3/16 brake line for this project. Your line with be a combo of steel and rubber. If your car has an automatic then there is a plastic T fitting in the rubber hose running to the carb (or FI if it's 250 or 29 ).
The judging manual describes this on page 58 of the 4th edition. Maybe the aims though will spell it out as Dennis said.
But to repeat you would have to at least have a short piece of steel line and fitting coming off the hex VA on your '890 distributor. John D.- Top
Susan, Look in the back pages of "The Driveline" for the Aims which is the Corvette Assembly Instruction Manual. Member price is $19.00. Just state that you have a 58. There is a separater manual for each year I believe. It's one of your most valuable resources. I assume you have the current Technical Info Manual also known as Judging Guide for 58 to 60. 4th edition.
I would have thought the guys would have jumped in with the answer already as I haven't been on line all day.
Good luck, John D.- Top
Susan,
Yes you need a 58 AIM to help you, but here's a view from my 59 Assembly Instruction Manual until you get your own 58 AIM. Looks like a similar setup as John talks about. You must have a base engine, 230hp?
You may need the special carb mount stud(for left rear of carb). It's hollow so it protrudes into the intake manifold to supply vaccum to the dist.
One caveat about the AIMs though. It won't always give you detailed info about the engine "assembly", as they were assembled in a different plant. The AIM was to assist vehicle assy and may not have all the engine details you need.
Hmmmmm, apologies......not trying to hijack the thread, but was there ever a engine "AIM"?
RichAttached Files- Top
- Top
Interesting John, thanks for sharing. Figured there had to be internal documentation at a minimum. It'd certainly be nice to have those available for us all. Too bad she didn't have a few copies lying around.
Rich- Top
