Just finishing a frame off on a 68 coupe. The body has been on the frame for two months and the driver's door worked fine that whole time. The inner door panel was put on the door, and the door opened fine several times that day. Now, the door will not open at all. Neither the inner pull nor the outer pull works. Since these are two separate mechanisms, I am thinking that the lock mechanism is the culprit.
When the key is inserted, there is an audible click but no release. Same when either the inner or outer handles are used.
Has anyone faced this before and, if so, how was it resolved ? Can the inner door panel be removed without damaging it ? Can the door be removed without damaging it ? Is there some way to release the lock without taking the door apart or the inner panel off ?
I should note that the locking mechanism is original to the car, but was removed, degreased, checked for operation and re-greased (white grease) before installing.
Any help will be appreciated.
Chuck Faillace
Chuck Faillace
