NCRS Judging of 67 Rally Wheel Letter Codes - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Are 67 rally wheel letter codes judged (B,DC,DG...)? Not too sure if there are even viewable via peeking through the valve stem hole in the rallye rings. Also, since the spares letter code is plainly visible is there a matching issue to the other four? Example, if I had a B coded spare with DC codes on all the other four would there be a deduct?
    Jim
  • Joel F.
    • April 30, 2004
    • 659
    Re: NCRS Judging of 67 Rally Wheel Letter Codes
    Jim,
    You hit the nail on the head: in most cases the rally wheel code is not visible with trim rings attached. In the odd case where you can see the code, it would be judged, but i have not seen many where the code is close enough to the stem to be visible with rings installed. One could always adjust the trim ring as well to improve one's score.
    As you note, the spare is judged and would lose points for the wrong code.
    Joel
    • Robert C.
      • December 1, 1993
      • 1153
      We only judge the spare tire code and date. You cannot see the codes/ date with the trim ring in place. The spare does NOT have to match the 4 running tires.
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1464
        Jim
        Current judging process is to provide full credit for a Factory Typical spare and as Bob points out, does not have to match the other four.
        Your code should be "DC" and the Judges do find ways to read the code while judging.
        Very early '67 cars DID have the "B" code wheel, so, you should receive full credit.
        Incidentally, what is the date inside your "B" wheel?
        I would like to compare with mine.
        H. a. N. D.
        • Jim V.
          • November 1, 1991
          • 587
          Originally posted by Mike Murray (25129)
          Jim
          H. a. N. D.
          Hello Mike,
          All four B wheels are date Aug 1966 ( 66 8). Were B wheels made for more than 1 month?
          Jim
          • Mike G.
            • July 31, 2002
            • 709
            spare is the only one that counts
            • Craig O.
              • July 31, 1983
              • 207
              I have a very early sept car has a B spare,two B and two DC mounted wheels
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1464
                Jim & Graig...
                Jim,
                Probably less than a month.
                I have seen "B's" into the early 700 VIN's on original cars. I have heard that they may have continued until about 1,200, but have not seen them.
                Craig,
                what is your VIN range? That may give us a better idea.
                Have a great day.
                Mike
                • Craig O.
                  • July 31, 1983
                  • 207
                  Hi Mike, It was a pleasure judging with you at CVF . vin 00364
                  • Mike M.
                    Director Region V
                    • August 31, 1994
                    • 1464
                    Thank you Craig, always a pleasure. Some great cars. (Some?.....)
                    One thing I forgot to mention.
                    Every production mounted "B" wheel I have seen also used the Schrader stem and cap rather than the Dill 627's and continued scattered longer through early production.
                    H.a.N.D.
