C3 1968 Lt. Brake Lights Stay On - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    All of a sudden the Left two brakes lights are on when the key is turned, but the right two work fine. Any suggestions?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C3 1968 Lt. Brake Lights Stay On
    Jack,
    I would suggest to check out the direction switch for the left side. Sounds like contact springs are in need of a tweaking. Brake lites and directionals are tied in in the steering column.
    • Jack C.
      • 1090
      Thanks. I looked at it tonight and it's in the switch. I moved the turn signal lever and they went out. It's very touchy.
      Jack Corso
