1957 chevy ignition switch removal - NCRS Discussion Boards
  • Jimmy B.
    • July 31, 1980
    • 584
    I apologize since this is a passenger car and not a Corvette.
    I am trying to remove the ignition switch from my 57 Bel Air and since I don't have a key (never got one with car), I cannot depress the plunger in the little hole with a pin (my switch does go to off - on - start), any ideas on what I can do now to get the switch off without tearing up my dash?
    Thanks for your help.
    Jim
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 1957 chevy ignition switch removal
    Not trying to be smart. See a good locksmith.
    • Donald L.
      • September 30, 1998
      • 461
      If you have a few old Briggs & Stratton keys you could jiggle the cylinder and it might turn. There were only a dozen or so combinations. Failing that a locksmith is the next step.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        I got lucky. Got a correct original ign switch for our 63, with "the wrong key" a while ago. I was able to pick the lock using a paper clip and one of those dentist picks.
        While keeping pressure counterclockwise, I picked around and around......and in about a minute I got it to turn and popped out. I chucked to myself......"Gone in 60 seconds!"
        Rich
        • Jimmy B.
          • July 31, 1980
          • 584
          Well, I got out my trusty drill and started drilling. My large bit broke. Now for the chisel, the outer chrome bezel came off and I was able to turn that big outer nut and walla, it is out!
          Of course I ruined my lock tumbler but I have a new set for the car so I didn't care.
          Thanks anyway.
          Jim
          tried my 67 car, the car "rejected" it. tried a NOS key blank--not even close!
