1958 neutral safety switch/relay - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    does some one have a diagram of the neutral savety switch part
    its not listed on the corvette electrical diagram
    or can you tell/show where ea. collor wire hooks up to on the relay
    thanks Sander,
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1958 neutral safety switch/relay
    thanks Sander,
    Looking at the relay on the fire wall -right post wire comes from the safety switch PG-left post from the starter key- bottom post to starter solenoid.This helped you?
    • Sander B.
      • March 1, 2005
      • 499
      many thanks Roy !!
      i will check it out now
      thank you Sander
