Does anyone know how to remove the vacuum actuator from the defroster door located in the heater box? I am hoping that I don't have to remove the heater box to get the vacuum actuator off. I uploaded a picture of the old actuator that is still attached to the heater box to show you which actuator I am talking about.
The vacuum actuator is located under the dash on the drivers side. I had to take the center console off to get access to it. But I can't see how to disconnect the actuator from the defroster door lever.
I uploaded a picture of the new actuator that I need to install. The lever has a hole near the end that is connected somehow to the defroster door lever. Is the actuator riveted on to the defroster door lever?
Any help would be appriciated.
Ken
Ken
