Inside lower windshield trim - NCRS Discussion Boards
  • Matt B.
    • August 31, 2001
    • 228
    Looking for suggestions on painting my inside lower windshield trim. It currently is painted black. My Fourth edition 66 judging manual says is should be painted low gloss to coordinate with dash pad color which in my case is dark green. I plan on sanding it down to remove paint runs and scratches. My question is, do I paint it with interior dye to assure it matches my interior? How would I achieve low gloss? Any help would be greatly appreciated.
    Matt Beltowski
    Florida Chapter
    Michigan Chapter
    Re: Inside lower windshield trim
    Matt -
    Assuming you have a rattle-can of the dark green dye, if you "dust" it on in several light coats, it will come out with a lower gloss than if wet-sprayed normally.
    • Matt B.
      • August 31, 2001
      • 228
      John,
      Thanks for taking the time to respond to my post. I will take your advice and spray a few light coats of the dye.
      Matt
      Matt Beltowski
      Florida Chapter
      Michigan Chapter
