Turn lights - NCRS Discussion Boards
Turn lights
  • Jim E.
    • November 1, 2007
    • 11
    Turn lights
    I noticed that the left turn signal indicator light in the dash panel stays dim without flashing. Neither of the outside turn lights, light. With the parking lights on both the front and rear lights work, so I know it's not a bulb out. I put in a new flasher, which is usually what causes this problem, but still not working. The right side works fine. This is on a '58. Any quick fixes?
    Jim
  • Ken B.
    • May 31, 2006
    • 233
    Re: Turn lights
    Sounds like a ground problem to me..
    • Jim E.
      • November 1, 2007
      • 11
      Re: Turn lights
      Thanks for the sugestion but if it was a bad ground wouldn't the lights not work at all?
      Jim
      • Albert P.
        • April 1, 2006
        • 205
        Re: Turn lights
        There are two separate filaments in the bulb, one for parking lights, the other for the turn signal; look at the bulb, it sounds like the filament for the turn signal is burnt-out; that would cause the flasher to not work as there will be insufficient current draw.
        • Jim E.
          • November 1, 2007
          • 11
          Re: Turn lights
          Albert,
          As I emailed you, went right out and damned if you were'nt right on! I never even thought about the possibility of two elements in the bulb. Got a pack of 10 just in case it happens again, or to the other side or rear.
          Thanks again,
          Jim
