Do I need the spacer behind the harmonic balancer on our 58 230 hp if I am installing a new replacement balancer (the later non riveted one)? Thanks
Balancer spacer question
Yes you do, especially if you are restoring the car. That spacer was added to Corvette only to make up for the Corvette only 1/8" front cross mount. It is what makes the pulleys line up. If you don't use it, you'll be using some other "bubba" method to align them. Best, Dennis- Top
