At cold start up and fast idle, oil pressure is between 65 and 70 psi.
While the engine slowly reaches operating temprature at idle, the oil pressure also slowly drops and holds at just above 20 psi.
When engine speed is increased to 1000 rpms or higher, the oil pressure responds instantly and holds between 45 and 50 psi.
I'm figuring even at 20 psi, the power plant is still getting completely lubricated, but I have never seen oil pressure on a small block that low at idle.
I have changed out the oil and filter but haven't fired the engine off yet to see if there is any difference.
Am I just being paranoid?
Chuck
Chuck
...Don't you believe that old gear head saying about "10 psi oil pressure for every 1000 rpm"?
