I need help a cam spec for 427 Tri Power L68 I am rebuilding the engine and the cam need replacing
Camshaft L68 427
Re: Camshaft L68 427
John-----
The cam was GM #3904359.
lift---intake=0.461"
lift---exhaust= 0.480
intake duration @0.050"= 214 degrees
exhaust duration @0.050"= 218 degrees
lobe centerline= 115 degrees
You can obtain a Crane-manufactured replacement of this cam (or, its rear journal grooved counterpart, GM #3883986) from GM under GM #12364055. This is a kit which includes lifters.In Appreciation of John Hinckley- Top
