Timing of firewall insulation vs pedal swing housing - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    I have looked at two 1967 Corvettes recently and in one has the pedal swing housing appears to have been installed after the firewall insulation; in the other one clearly the insulation piece (held in place with the rubber fastners) was installed over the pedal housing attachment bolts on the firewall. Can anyone recomend the correct installation sequence. I thought the firewall insulation went on first, but I could be in error.
    Thank you
    Tim
    Director Region V
    • August 31, 1994
    • 1464
    Re: Timing of firewall insulation vs pedal swing housing
    Pedal assembly, then insulation.
    H.a.N.D.
