Guys,
I just swapped out the rear carrier on my 340HP 1963 (close ratio BW). It had 3.36 gears and I went to the original 3.70 ratio. Driveability, particularly at low speed is much better however at highway speeds (65-70MPH) I'm getting a vibration in the rear.... too much to be acceptable.
Other than replacing the carrier (Ikerds) as a unit everything else back there is the same as before; drive shaft, half shafts,etc..
I'm thinking that I may have an issue with the drive shaft which was not evident before with the higher rear...
Anybody run into this issue and/or have any thoughts...
Joel
Joel
