C1 Brake fluid quantity - NCRS Discussion Boards
  • Bob S.
    • August 12, 2007
    • 185
    Doing a complete brake system rebuild on my '59 (new lines, wheel cylinders, etc). How much brake fluid should the system need using the original master cylinder?
  • Donald B.
    • May 31, 2004
    • 299
    Re: C1 Brake fluid quantity
    There are two parts to the answer - first, how much do all the componets hold - less than a quart. Second, how much will you use to not only fill the components but also to properly bleed the system - probably more than one quart but should be less than two quarts.
    • Bob S.
      • August 12, 2007
      • 185
      Thanks Donald. That's what I needed.
