Can someone confirm the ignition shielding for my 72 car. We have recently aquired this car and are headed to Bloomington with it for a survivor certification. In looking the car over there is only a ignition shield over the rear two spark plugs on both sides (including the uprights and the distributor cover). The assembly manual shows this set up also...I have a couple of midyears and they have shields on all of the plugs. So...any insight will be helpful. Thanks, Henry
72 ignition shielding
Re: 72 ignition shielding
Henry,
If you're asking about a 350 engine car you're right. There are just shields for the rear pairs of plugs along with the V-shaped shield on each side. This info is in the Tech Guide, Mechanical, Section 10.
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
Thanks Guys...I really appreciate the confirmation. If you are at Bloomington...look for us...we will have a 72 Blue/black A/C, power windows, tilt tele...I bought the car from the original owner last fall. Thanks again. HenryHenry Atsma
54 White/Red
63 Red/Black SWC
67 Elkhart Blue/Black BB Roadster
91 Black/Red ZR1
96 CE - LT4
07 Red/Tan- Top
Henry,
I notice that you're from Michigan.
Where?
PatrickVice-Chairman (West), Michigan Chapter NCRS
