Does anybody have a recommendation for a good timing light that one can purchase for the older cars?
Timing lights
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
Re: Timing lights
I've used a standard Craftsman (Sears) timing light for this task.
Stock engines do not need 'dial back' timing lights. They are only needed for all out performance applications (Racing)!
Consult your model year shop manual for timing instruction.- Top
Re: Timing lights
here is the one i use powered by flashlight batteries, just clip on the inductive pickup to the plug wire. no need to look for 12 volt power. http://www.autotools.com.au/catalogu....php/10/73/740- Top
Re: Timing lights
Mark,
You are right. I used to race a big block Camaro and that was the reason I bought the dial back light. I just got spoiled by it and continue to use it on stock engines. I also have a standard style light, but always reach for the dial back one.......
Tom1958, 283/245, White/red - Top Flight, October 2016
Re: Timing lights
I have an Actron dial back timing light that I think I paid $50 for and has served me well.
Mark, how do you set your mechanical advance without a dial back (assuming you do not have a degreed balancer)?- Top
Re: Timing lights
dial back timing lights were designed for electronic timing advance systems and i would be nervous using them on a points type system where the dwell varies and so does the timing. also i would NEVER use one on race engine where you check total timing advance at max RPMs. JMHO- Top
Re: Timing lights
Thanks Clem,
I am not trying to be argumentative but using a dial back is the way I was taught (and I have learned a lot of other bad habits as well). That said, how would you set the advance without one? I'm not comfortable just going by initial timing.
Joel- Top
Re: Timing lights
when i worked on engines used the total advance method, check for max advance at max RPM. degreed the damper off for total degrees.Thanks Clem,
Joel- Top
Re: Timing lights
Thanks Clem,
That is about what I figured. My balancer isn't degree'ed, but next time I have access to the balancer I'll add some timing tape just to have something else to go by.
Joel- Top
Re: Timing lights
measure the circumference of the damper and divided that number by 10 and that distance from TDC will be exactly 36 degrees- Top
