Hi All,
I'm helping to prepare a 64 for our Regional. We're running into an issue with the electrical system and I'm not sure if it is related to the wiring, a switch, or both.
Using the headlight switch, we can get the front running lights and the headlights to work. We cannot get the dash lights or the rear taillights to work via the headlight switch. We have tried 3 different headlight switches and even rebuilt one, but no change. I find it hard to believe that 3 switches are wrong. We've tested them and it seems like there should be an external jumper to connect the two internal halves of the headlight switch.
If we remove the headlight switch and run a jumper from the hot red wire to the correct wires (brown for rear, dark green for dash lights) we can get those lights to work.
Any ideas?
Patrick
Any ideas?
Patrick
