I autocross my 67 327/350 roadster a lot, so when I redo the engine this fall/winter I'll swap the stock oil pan to a 63-65 FI pan with an extra quart of capacity (up to 5 quarts in the pan) and a cool little trap door. As far as I know, the depths of the two pans are the same, and they differ only in length.
My car has its stock oil pump, which is a different item than listed for a 63-65 FI car. Since the two pans mentioned above differ only in length (presumably), what is different between the stock 67 and 63-65 FI pumps? Is it really necessary to swap oil pumps when I swap pans?
