Broaching original engine pad 1962 - NCRS Discussion Boards
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    After having my 62 340 hp car judged, I became aware of circular marks on my engine pad. The motor is orininal, the numbers all correct.
    Questions: 1. Could a member supply pictures of original pads to replicate? 2 Technique for applying broach-like marks ?
    My pad is without any marks circular or parallel , only original numbers.
    Appreciate the assistance, Lynn
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Broaching original engine pad 1962
    My pad is without any marks circular or parallel?
    I would leave it alone. How many points did you lose on the block?
    Lyle
    • Lynn L.
      1953-55 Team Leader
      • February 1, 2000
      • 162
      I lost 38 (all asigned) original pad points. The numbers received full value points. lynn
      • Rick A.
        • July 31, 2002
        • 2147
        as was mentioned, I would not touch the pad
        Rick Aleshire
        2016 Ebony C7R Z06 "ROSA"
        • Harmon C.
          • August 31, 1994
          • 3228
          Lynn
          It would be alot of work to try to gain any points at the risk of having a greater amount of points taken with redone numbers. Also if you have your car judged again let the new team make their own decision. Don't tell about the last time and see what happens. You know the numbers are original keep it that way.
          Lyle
          Lyle
