1962 Corvette Jack-Original vs Exact Repro - NCRS Discussion Boards
  • Bill O.
    • April 1, 2006
    • 542
    Can anyone describe the appearance differences between the original and current "exact" repros. Might be the relative size (diameter) of the roller bearing, the position of the small hole back of the large hole that the jack tool fits in ( 12 O'clock vs say 10 O'clock), absence of the stamped "A", number/location of spot welds seen on the base bottom holding the feet in place. I need help BAD (ly)
    Any knowledge you have here would be most welcomed.
    Thanks, Bill
  • Bill O.
    • April 1, 2006
    • 542
    Re: 1962 Corvette Jack-Original vs Exact Repro
    Any '62 guy out there with an original jack...one question....is the stamped steel base welded to the bottom saddle with 2.....or 4 spot-welds?? Any help would be appreciated.
    Thanks, Bill
