Strange 427 casting numbers (early '68 321 block) - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    A friend has this block and I understand it could have been found in early '68 Corvettes (up to Jan '68). This one is definitely not from a Corvette, but have any C3 people seen these 'upside-down' casting characters ? And just what the heck is the '2BT' suffix following the Tonawanda assembly date of November 10th, 1967 ?
    The shots of the rear bellhousing flange area are taken standing behind the motor with top of pic being towards the front. Both the casting # 3916321 and 'HIPER' are turned around from the normal placement. The casting date is by the starter nose and is 'I_17_7' (17th Sept, 1967).
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Strange 427 casting numbers (early '68 321 block)
    Ref. the 2BT suffix- usually a digit followed by two alpha characters is a marine installation, with the digit representing the year of manufacture. This might not make sense in this case with 2 being 1972 (?)
    Dunno.
