1962 Fuel Pump - NCRS Discussion Boards
1962 Fuel Pump
  • Stephen B.
    • April 1, 1988
    • 876
    1962 Fuel Pump
    I've been led to believe that this item is an original 1962 fuel pump. Can someone please give me guidance. Thanks, Bunky
  • Mike M.
    • April 1, 2007
    • 60
    Re: 1962 Fuel Pump
    Original 62 fuel pump was # 4656.
    • Stephen B.
      • April 1, 1988
      • 876
      Re: 1962 Fuel Pump
      Then I wonder what this fuel pump's application? Is the "4657" the last four digits of the part number? Thanks for you help.
      • Mike M.
        • April 1, 2007
        • 60
        Re: 1962 Fuel Pump
        I have a 4657 on a 300 HP, 327 out of a 62 Impala SS its original I'm sure it has other applications.
        • Bernard M.
          • August 31, 1994
          • 341
          Re: 1962 Fuel Pump
          I believe a 4657 is original equipment on at least the lower horsepower '63 Corvettes.
            Re: 1962 Fuel Pump
            The 4656 fuel pump was used '58L-62. The 4657 fuel pump is virtually identical with the exception of the 'clocking' of the body relative to the upper pump section and was used for '63-65 EXCEPT for high horse (L76, L84) engines.
            The unit pictured appears to be a service replacement (later build) since the lower gasket lacks the curvy white reinforcing stitch lines normally associated with factory original fuel pumps from that era.
            • Stephen B.
              • April 1, 1988
              • 876
              Re: 1962 Fuel Pump
              Thanks for everybody's help. I found it in the mid-year interchange manual.
