Tyre Fitment - NCRS Discussion Boards
Tyre Fitment
  • Joe C.
    • August 31, 1999
    • 4598
    Tyre Fitment
    Dear Sirs and Mesdames:
    I have been well advised by a most knowledgeable, and respected chap, that a size 215/70R-15 tyre will neatly fill in for an originally fitted 7.75-15. If the following link is used:
    http://www.miata.net/garage/tirecalc.html
    then, a compatible size will be 235/65R-15. Have any of you gents, and/or, ladies, actually fitted this size tyre onto your Midyear Corvette? Were there any rubbing issues. I am currently employing Western, aluminium knock-off wheels.
    Have any of you gents, and/or, ladies, experienced these tyres, notwithstanding the fact that they are not available in size 235/65R-15:
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Tyre Fitment
    Just before moving from the northern midwest to Florida, I finally changed my 63 over to radials after many years running correct 6.70/15 or 7.75/15 Bias ply tires (tyres) for most of it's life. I went to a Goodyear shop where a GM trained Corvette specialist worked and he recommended I go no bigger than P205/75R-15's for use on my stock 5.5" wide steel wheels. He also did the most important thing for me; and that is the "neutral" front and rear wheel alignment. This was done on a computer controlled machine from which I have a printout. My rear adjusment had to be run out to the maximum to achieve the necessary specifications. I put my faith in his years of experience changing old Corvettes over to radial tires, and I feel it paid off. It tracks beautifully straight and handles/rides like a dream. In looking at my car, specially turning up and down drive ways, I can honestly say I don't think I would want to try any larger tire than these. The other criteria I used for picking the tires was the speed rating. I'm inclined to push it to the red line at least in the first 3 gears and a bit beyond once in a while and did not want a tire that was going to give up on me at speed. Oh yes, I have a 3:36 rear axle ratio so it loves to run right up there with some of the big boys.
    Stu Fox
    • Wayne W.
      • April 30, 1982
      • 3605
      Re: Tyre Fitment
      http://www.tirerack.com/tires/tires....e1=yes&place=0
      I run 215/70s on my 66 with the KOs and they do fine. Cant advise on the 235/65s.
      • Michael H.
        • January 29, 2008
        • 7477
        Re: Tyre Fitment
        Just my personal opinion but I think 235/65's would look stupid on a 63-67 car. Way too short for the body style. I really don't care much for 215/70's either.
        As mentioned, a good quality 205/75 will look great and perform very well.
        No matter what ya do, ya ainta gunna make yer C2 handle like a new Z06. Enjoy the car for what it is.
        • Bruce B.
          • May 31, 1996
          • 2930
          Re: Tyre Fitment
          I have Goodyear Regetta 2, 215 70 R15 tires on stock steel wheels on my 65 coupe and they look great.
          The only problem I have is that on a tight left turn the tire rubs slightly on the frame rail toward the rear of the car. Other then that the car handles well.
