I'm pretty sure that now is the time for the black-out procedure but just wanted to check with you all before I do something stupid. Have a look at my pic and see if it looks ready. I don't think the wheels should be on so that is why they are still off.
For the actual procedure it was just one or two quick passes to cover the outboard side and the bottom of the mufflers and nothing was masked, correct? Also was the black-out pretty much flat or a semi gloss like under the hood? I would lend to think that they would both be the same but I think the body black-out and chassis black-out were done separately so I'm not quite sure about this.
For the shim markings should they be actual numbers or slashes? This is a late Jan 69 car.
Thanks.
Thanks.
I couldn't justify replacing a perfectly good AND date coded tank just for the sake of any pre body drop chassis pics. I'm not at all pleased with the "tank tone" and there is no way I'd ever use it on a car where you can see the tank like on a "A" or "F" body.
