I've read Dukes posts on oils and ZDDP, and also searched the archives, but I still couldn't tell how to respond to my father who sent me the following, which was passed on to him by a friend.
I had never heard the part about about diesel oil and bearing clearances.
-Dave
PREVENT DAMAGE TO YOUR ENGINE!
Over the past 20 years, unknown by most, motor oil manufacturers have been incrementally reducing the amount of a major component in motor oil. The reason behind this is to keep our air clean by increasing the life expectancy of catalytic converters in new cars up to 100,000 miles or more. That is fine, but what about cars without catalytic converters?
The oil component in question is ZDDP *. This oil additive has been used in motor oil for almost 70 years to handle areas of extreme pressure like flat tappets and camshafts, wrist pins, pushrod ends, rings and so forth. Car manufacturers have tried to address this in newer engines by using roller lifters and re-engineering other areas of extreme pressure.
Older engines (pre mid 1990s) using the new oil formulations are not fully protected as they have been in years past. About 3 years ago engine builders noticed a marked increase in engine failures. One engine builder said that he experienced more engine failures in 3 years than he had in the last 30 years. A search began to find out the cause and they discovered that the oil formulation had been changed. In 2005 the level of ZDDP in motor oils had been dropped to below the minimum level recommended by automotive engineers.
See our website at http://www.zddpoiladditive.com/for links to articles by Hot Rod magazine, High Performance Pontiac, Comp Cams, American Engine Rebuilders Association and others that discuss the problem. Or search for "ZDDP" in Google to see the thousands of discussions and articles.
Once the problem was understood, alternative solutions began cropping up. These included using diesel engine oil and racing oil. However, both of these have their shortcomings when used as the motor oil in a street driven gasoline engine. Oils for diesels are designed for engines with different bearing clearances, different viscosity needs, and are very high in detergents. Racing oils are very expensive and are not designed for long term use and do not usually come in the viscosities needed for a regularly driven vehicle.
Our new product ZDDPlus was created by car enthusiasts for car enthusiasts. Now the answer to the problem is simple, just replace the ZDDP in your favorite brand name oil by adding one 4 ounce bottle of ZDDPlus at each oil change. Instead of guessing that you have the correct level of protection, ZDDPlus ensures that you have the correct level of protection. For approximately $10.00 per oil change it is cheap insurance. ZDDPlus was created to fill the needs of collector car owners.
See detailed information on ZDDPlus at: http://www.zddpoiladditive.com/zddplus.htm
Our company ZDDP Oil Additive is your source for ZDDPlus. Our mission is to supply you with ZDDPlus as quickly as possible. We have the product in stock and we will ship it to you immediately.
If you are an officer or member of a car club you may want to inform your club members of the ZDDP issue in your newsletter or web site. Feel free to use the information in this email, our website or the links in our website. We recently talked to an old friend who we had not talked to in some time. He just went through 2 new Chevy crate motors. One of the engines had a quality control problem but the other had a camshaft that went flat even though he used the recommended break-in procedure. Please don't let this happen to you or your club members and call us if you have any questions.
ZDDPlus Pricing:
Single 4-ounce Bottle of ZDDPlus $9.95 plus $6 shipping
Four-Pack of the 4-ounce Bottles of ZDDPlus $39.80 plus $8 shipping
Six-Pack of the 4-ounce Bottles of ZDDPlus $59.70 plus $8 shipping
For California orders sales taxes apply
Call us for club discounts on larger quantities
-Dave
ZDDPlus Pricing:
ZDDP Oil Additive
P.O.Box 4547, San Dimas, CA 91773
Phone 909-392-8440
