'67 AC Car Battery Access Panel Question
Re: '67 AC Car Battery Access Panel Question
First let me say that there could have been some differences through the years or from AOS to St. Louis. It will take some time to document. But for what its worth , here are some pictures.
First this should prove the body was undercoated before black out.
Note black paint on engine side of the panel.
Note black under the tape for the weatherstrip.
Continued, Note Black under undercoat on wheel side, and remnants of black under the socket heads.
Note the imprint of the grain in the weatherstrip and the undercoat under the panel overlap.
The panels with paint showing under the bolts certainly do make a statement, don't they.You were there. You tell me. Would those guys install that panel on the line, as hard as those bolts are to get to and start, run them down tight so that paint couldnt get under them, do the black out, and then remove it for body drop? I dont think so. I have examples that have paint under the bolts.
The pic's are interesting. But so are some other pic's that seem to indicate that the panel was in place during undercoat/blackout.
I dunno.
A logical assembly sequence would suggest that the panel WAS in place during undercoat/blackout because there is no reason that I can think of why it shouldn't/couldn't be.
Why would the installation be delayed until after body drop? The battery would have already been sitting in the tray and I can think of no other reason why it might have been added later. Sure looks like it was though.- Top
With the battery in this forward in this position, you cant drop the body straight down. I have never really tried it, but I dont think that panel was on the car when the body came down. That is what I am saying.The panels with paint showing under the bolts certainly do make a statement, don't they.
I dunno.
I dont know where the rest of my pictures went. I hate this new format. So I will post them again.
Paint under the undercoating on the wheel side.
Note paint under the blackout on the wheel side.
[IMG]http://i238.pho[IMG]http://i238.photobucket.com/albums/ff142/wombvette/66FactoryBodyBuild.jpg
On the encine side.
Under the tape.
Note the imprint of the undercoating on the seal, and the undercoat in the lap joint of the panel.
I have to agree, the panel from your car appears to have been painted/undercoated before it was installed.
Pictures of others show that the panel was painted/undercoated after it was installed.
I don't think a conclusion can be reached with the info that's been submitted so far.
More research is needed.
In the meantime, I don't think there should be a point deduction for either method used during restoration.- Top
Agree ...
Here's some more from early '65 A/C, 014xx, S-body. All from wheelwell side. First thumbnail is of overlap zone, top of battery panel; (remember) this panel never had any foam seal, and the undercoat flowed down.
2nd pic is a little to the right of first, showing outboard upper corner. You can see no undercoat in the overlap, but blackout is there. If you look closely to the left of the bolthole, you can even see some of the original Goldwood yellow lacquer, before blackout. Third is overall shot of panel; much less undercoat than my 396 panel (earlier post in this thread). Fourth shot is of lower outboard corner, showing native fiberglass, blackout, then undercoat. The light gray is overspray primer from a latter re-paint in 1983.
I'm not saying that all S-body battery access panels should be the same. Just offering this for comparison.- Top
