C3 427/400 Carb Vacuum Line Black or White? - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    The TIMJ refers to the rubber vacuum hoses as being black with no mention of the white stripe? Also mentioned, that there are two spring clamps, one on the vacuum advance hose and one on the steel vacuum line hose. Is this correct. This is an early January 68 Built car.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: C3 427/400 Carb Vacuum Line Black or White?
    Originally posted by Jack Corso (21713)
    The TIMJ refers to the rubber vacuum hoses as being black with no mention of the white stripe? January 68 Built car.
    Jack -- all I can say is that on a later '69 L68 set-up (4055 center carb dated 981) the vac hose on the choke diaphragm is thick black rubber with 3 ribs; believe it is original. Can't answer your other questions.
    • Jack C.
      • 1090
      I looked at Dobbin's book and it clearly shows a white stripe. Thanks.
      Jack Corso
