Would the sticker found on the firewall above the master cylinder on a 70LT1 show 350/370 on the sticker or 350/350? Thanks
Sticker under hood 1970 LT-1
Re: Sticker under hood 1970 LT-1
Chris----
The emissions label should be coded "CT", although it's possible other-coded labels were used, too. In the text of the label it says "350 cu. in V-8 360 & 370 hp." The same label was used for 1970 Z-28 Camaros and that's the reason for the reference to "360 hp".In Appreciation of John Hinckley- Top
Thanks Joe....the car I have is a 350/350, however the console plate has 350/370. The motor has never been out of the car and it is an original 14k mile car. It was modified to look like a Motion Performance car back when it was new and I guess it's possible the original owner changed the console plate. It is a CTH stamped motor which is correct for the 350/350 with M/T. I took a photo of the sticker, but don't know how to include it with this response. Thanks
Chris- Top
Chris----Thanks Joe....the car I have is a 350/350, however the console plate has 350/370. The motor has never been out of the car and it is an original 14k mile car. It was modified to look like a Motion Performance car back when it was new and I guess it's possible the original owner changed the console plate. It is a CTH stamped motor which is correct for the 350/350 with M/T. I took a photo of the sticker, but don't know how to include it with this response. Thanks
Chris
If you wish, you can e-mail it to me and I'll post it for you. If it's an original 1970 L-46, I expect the emissions label code will be "AX", but other codes may also have been used through the model year.In Appreciation of John Hinckley- Top
