Re: C1: Crate engine or rebuild?
Robert,
Being it's NOT the original block, I am not sure why so many are arguing for you to rebuild ??? I agree that if you go the crate route you'll have serious problems making it look original.
But, If you go the Crate route, and there are MANY possiblilites, you'll be back on the road much earlier (able to Drive and enjoy) and then you can take time to find correct parts....if funds permit.
If you have the finds and patience, you could probably find the required period correct parts.....but in the mean time, get something in her and enjoy.
JMO - David
The engine is a 327 but was a short block, installed in the 70s. So the engine number does not match.
I'm assuming that since the engine number doesn't match, the value will be the same: rebuild or crate.
Should I rebuild the current engine or go with a crate engine?
JMO - David
