55 Steering shaft removal - NCRS Discussion Boards
  • Tyler T.
    • August 31, 1981
    • 282
    If you remove the radiator asem, grill and disconneft the pitman are can you remove the steering box and shaft from a 55 without lifting the body?
    Thanks.
    Tyler
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55 Steering shaft removal
    Thanks.
    Tyler
    Yes with a little damage to the left inner fender panel ,
    • Tyler T.
      • August 31, 1981
      • 282
      OOOOk thats out.
      Thanks.
      Tyler
      • Roy B.
        • February 1, 1975
        • 7044
        Tyler It's not that bad , but some have heated up the cast box to remove the column out through the dash then pull the assy. But again with a little wiggling and some scratches of the inner panel it can be done.(remove the pitman arm. )
        • Michael L.
          • July 31, 2005
          • 562
          Weigh out the time to pull the body vs. repairing a few scratches. I did mine body on, not too bad, the fenderwell flexes... Your call.
