1972 door weather strip - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Is original door weatherstrip one or two pieces? I understand the original weather strip is split at the under side (bottom) of the door and accordingly two pieces? What's correct?
  • Tom L.
    • May 7, 2007
    • 438
    Re: 1972 door weather strip
    The original door weather strip on my '70 is in two pieces. The seam is roughly in the center of the bottom of the door. As I recall, my '71 was the same way.
    • Jerome P.
      • October 22, 2006
      • 607
      Tom are the two pieces butted tight or is there a gap? If a gap, how large is the gap?
      Thanks Tom.
      Jerry
      • Reba W.
        • 932
        I have seen some with an one-inch gap and some with two inches and more. Some are almost centered, while some are toward the front. The judging manual gives a good description of this. I judged several at Michigan this weekend that were one piece.
        • Erik S.
          • January 1, 2005
          • 407
          Jerry - I have a fairly detailed picture that I took during this year's judging retreat in Dallas when I was judging the 71 LS6, which received all the relevant survivor awards. I will post it later today as I have it on another computer.
          Erik
          • Harmon C.
            • August 31, 1994
            • 3228
            Install the new weatherstrip in one piece. Before judging make a cut in the bottom to make it look correct with a new razor blade.
            Lyle
            • Tom L.
              • May 7, 2007
              • 438
              Jerry,
              I'll post a picture when I get home tonight.
              Tom
              • Tom L.
                • May 7, 2007
                • 438
                How do like the fancy paint job?
                Although the paint job is disgraceful, the weather strip and the gap appear to be original.
                • Erik S.
                  • January 1, 2005
                  • 407
                  here's the pic as promised - 71 LS6 drivers side door.
                  Erik
