at this thread: https://www.forums.ncrs.org/showthre...ldest&uid=3961
Chuck wrote in a response:
"Your best shot at determining the original finish on fasteners is to examine the individual fasteners closely for any remnants of the original finish. This is best done during the disassembly process as they are cleaned, bagged and tagged.
Fasteners that were originally black phosphate or natural are the ones most likely to be rusted beyond recognition. Black oxide is a tougher finish, but application is more selective in my experience. Black phosphate will have a fine crystallaline structure in the finish that reflects light; its somewhat like looking at your concrete driveway in bright sunlight. Black oxide is a slick, hard finish compared to black phosphate. Be careful not to identify worn black oxide as black phosphate; the black oxide may have have near-microscopic flecks of plating missing that makes it appear as black phosphate (it's happened to me). Zinc plated fasteners should show some sign of the original finish under the worst conditions in my opinion.
If all else fails, feel free to apply my arbitrary rules of thumb on fastener finish. These are BFG (BIG FAT GUESS) or ALR (ABSOLUTE LAST RESORT) categories; USE AT YOUR OWN RISK: For chassis fasteners, say 1/4" and larger, use black phosphate. Fasteners 3/16" and smaller could be either black oxide or black phosphate. Zinc is used on the chassis sparingly, but you should be able to see where. Natural fasteners are also used on the chassis in a few applications; you will almost have to know these from observing restored cars or reference books."
I am trying to use this methodology - here is a case in point - I took off the axle shafts last night from a 1970 - the bolts that secure the outer shaft flange to the spinder dirve flange (UPC4A2 - 2; page K168 in the Mid America AIM) can serve as an example - they were dirty, but not rusty - I rinsed them for a few minutes in mineral spirits - the result, bolts that look "grey" - the first thing I did was consult the TIM (4th Ed., pp 103 and 110) - but I cannot find any reference to bolts at all - does the TIM not deal with what markings the bolt head should have and what finish? - if yes, I could not find it - Chuck's post says that for certain fasteners (e.g., "natural" finish), one has to refer to a reference book - assuming this is not the TIM, what is it? - I otherwise have searched the archives, and could not find anything on this specific bolt finish (bad searching?) - so, since all else I can think of has failed, I'll ask you guys...what finish should this bolt have? - and going forward, is searching here and if unsuccessful, asking, the only way to know about correct fastner finishes? - thanks and sorry for the long post! sl
